May 2020 Product Adoption Tip: Alternate Hierarchy Setup
Problem: I need the ability to create a separate dimension hierarchy structure for different reports.
Solution: Alternate Hierarchy functionality allows you to have more than one hierarchy to consolidate dimension members in multiple ways for reporting needs. For example, cost centers might be aggregated one way for management reporting and another way for the legal entity reporting. The default dimension hierarchy structure in Model Manger can be setup with the legal entity structure. For management reporting, an Alternate Hierarchy can be used.
Tip #1 The alternate hierarchy can be used in any dimension, except the Account dimension.
Tip #2 The alternate hierarchy functionality is used only for reporting purposes. You cannot perform data entry in, or run a process for, an alternate hierarchy structure.
Tip #3 You can have multiple alternate hierarchies within the dimension.
Steps to set-up Alternate Hierarchy: for Organization Dimension
  1. Open the Organization dimension.
  2. In the lip, click on Edit custom member properties.
  1. We need to add a new property. Click Add . Choose Add New.
  1. Enter the following:
  • Name: Legal Entity
  • Description (optional)
  • Data Type: Text
  • Default Value: North
  • Table Column Name: Legal
  • Size: 100
  1. Click OK . You should now see Location appearing in the Member Properties for each of your members.
  2. Type in a location for each leaf member. Choose from North, East, and West.
  1. Save your changes.
  2. The next step is to create an alternate hierarchy that groups my members by region. From the lip, select Edit Alternate Hierarchy.
  3. Click Add.
  4. Enter the following:
  • Hierarchy Name: Region
  • Level Name: Legal Entity
  • Member Property: Legal Entity
  1. Switch to the Preview tab. Here you can see the new rollups you defined.
  1. Save and Publish. You will now see the option to select the Alternate Hierarchy when creating data view.
Let us know how this works!
I am not currently using this hierarchy setup as that is handled by our expense admin
We have not used the alternate hierarchy but might be something we could use.
I have not tried this. Very interesting though
I think this could be a good solution for a multiple ways of reporting once I get my head around it, thanks for sharing
We have used alternative hierarchies to generate various management reports. One of best features in Prophix.
These are a great feature!
This is not handled by me. Our expense team is in charge of hierarchy setup
This might be handy with our Tech business partner portfolio, identifying new approved/not approved projects… interesting!
We use this to show different report of cost center based on locations. Very useful to give different grouping & perspective.
We do not use this yet, but we have plans to in the future!
Great feature! Thanks!
I’m a new admin - this tip was great information.
I will need to think about how this could be useful for our company. I bet it could be.
We definitely use this!
Great info and useful for sure!
