We did a model audit with Bryan and were very happy that we did. It is a great service that Prophix provides. It helped to ensure that our model was operating at peak efficiency.
August 2020 Product Adoption Tip: Tried Any of the Tips From the Model Maintenance Guide?
I plan on utilizing them - thank you for sharing them!
These are really helpful, especially as we start the new year. I’m going to do the suggested steps to reduce the size of the database.
Thank you for the tips.
Thank you for taking the time to share this.
This could be very useful, thank you
We use the remove data process to remove zero’s with most of our import information processes.
We use remove 0 data values from the data process a lot. Def speeds up the process
I run optimize processes and remove zeros regularly.
working through big model maintenance and clean-up effort now!
To help further improve model efficiency Advisor was introduced. Global Administrators can run Advisor to identify any opportunities for performance improvement. Check out more info here in our online help.
These snips of tips are great!
