Designing Report & Data Entry Templates
With budget season looming, it’s important to ensure that your budget templates and reports are capturing all your dreams and desires!
Template Calculations
When it comes to creating your budget, it’s important to think about how end users create their budget. What KPIs or calculations come into play? If multiple factors or inputs are utilized, template calculations are extremely useful!
In Design Mode, you can enter the calculation into the cell with the desired member combination, replacing the default “1,235” amount with the formula. For the data to be saved to the cube, the member combination must be at the lowest level. Additionally, refreshing your report will confirm the data is written to the cube, or you are running a “Template Calculation” process in Process Manager.
Some common examples of Template Calculation formulas are taking your Actual data and incorporating multiple factors to create your budget and allocating amounts that are too specific for Infoflexes to be used.
Row Notes
Now that you have that level of detail in your budget creation, what is another way to add additional insight? Row notes, of course!
In Design Mode, you are able to insert Row Notes which allow you to provide commentary to your report, without having to click into a specific cell. The text written into the Row Note when in Data Entry mode is saved to the cube, and can be referenced in other reports utilizing cell reports.
Not only are row notes important for the budget, but can provide extra insight into financial reports! You’ll be able to add commentary on your actual data throughout the year, and give explanations on variances between actual and plan data.
Multiple Data Views
Now that you’ve created your budget, you’ll need reports to showcase your plan. What is better than creating a consolidated report, outlining all key aspects of the company!
Building out a consolidated report may require multiple data views, and sometimes even multiple cubes. In Template Studio, you are able to insert more than one data view to create a report. Data views can also include calculations referencing the other data views in the template. To simplify your report, you will want to consolidate your pages using “Page Hierarchy Groups”. For each common dimension, you are able to group them into one page when running the report. For example, if Time is in the pages for each data view, you can group it into one page. Not only does this clean the presentation, but the member selection of this page group applies to all dimensions.
Reports where multiple data views are typically used incorporate data views from the Financial Cube, Revenue Cube and Personnel Cube into one report!
Happy budgeting !
What are your favorite uses of template calculations, row notes and reports with multiple data views?
The recorded session can be viewed on Prophix Academy
Click here
I was attending another session so could not attend this one
Hi Imtiaz,
If you added the session to your agenda, you should be able to view the recording later on. We will also be attaching a recording of the session to this post.
Great summary points
Enjoyed the: Design Mode: Insert Row Note … Data Entry Mode: Add Comment (select wrap text) … Report Mode (read only) … 3 steps very nice
Just watched this On Demand as it was on in the middle of the night for us. Will definitely be incorporating row notes in future reporting. We use template calculations in our budget templates using 4 data views and it works well.
I’m in the wrong time zone to see this live, but this sounds very useful and I look forward to seeing the recording. Thank you in advance!
I’m planning to use row notes more this budget season!
I would like to know what the best practices is for the maximum number of data views in a report.
Hi Emily! There is no concrete number as it depends on size of the data views being used. When adding data views to a template, previewing or running the template in Report Mode will give you an idea of the performance of the template.
What are the next steps in your opinion on best practices? I am excited to implement at Moneris
Hi Dawar,
Is there a particular feature within template studio you would like best practices on?
Template calculations were the biggest game-changer for us!
This topic was automatically closed after 47 days. New replies are no longer allowed.
