Hi Prophix user group,
Our model manager database was changing by itself for no reason. We are wondering if there is a way to export the model manager data and check. Thanks for your attention and help in advance!
Hi @gloria.zhang!
By model manager database, do you mean by dimension?
If so, you can create an export dimension process in Process Manager and export each dimension.
For example:
And select the dimension you’d like to export:
Hopefully this helps!
Thank you very much Sydney it is very helpful!
A follow up question, if I choose “Data Connector” as target, will it be added to the folder or overwrite my table.
@gloria.zhang, I just confirmed with one of our data integration engineers - this would overwrite the table.
Thanks again Sydney!
