Budgeting with Prophix Line Item Schedules is easy and powerful. Organizations can be more organized, flexible, and detailed in their budgeting, which makes it easier to analyze the budget information.
The Line Item Schedule feature in Prophix enables you to enter account data at a more detailed level based on multiple lines of transactions that populate the account total amount. A common use case for Line Item Schedules is when an organization would like to do subledger planning. Each transaction line represents a different expense or revenue item that affects the total value of the account. Expenses such as office supplies, marketing expenses, or travel expenses can be broken down into multiple categories.
This article explains how to populate an account using a Line Item Schedule.
We will assume that travel expenses are to be populated exclusively through a Line Item Schedule so that we can break down expenses into more cost segments for in-depth analysis.
Step #1: Model Manager - Account Dimension Set-up
- Go to Account Dimension in Model Manager, and locate the Travel expenses accounts
- Navigate to the Calculation Definition section on the right-hand side
- Choose the option that Requires line item detail for data entry under the Calculation Method
Note: Apply the same steps for all leaf-level input accounts that require the same actions.
Step #2: Data Entry - Line Item Schedule
The next step in Ad-hoc Analysis is to use what we selected in Step 1. To populate the travel accounts, I created a simple data view with data entry enabled.
- Open the data view and enable the Data Entry Mode
- Upon entering data, you will be prompted with a message saying, âThis account can only be updated using Line Item Schedules.â as supporting detail
- By clicking Ok, youâll open the Line Item Schedule screen and be able to populate the account with information
- Complete the supporting details in the account as needed. Once the data entry is complete click Save. Upon returning to the data view you will find the account populated accordingly
Step #3: View Line Items Schedule Report - Supporting Details
After populating the target expense account via Line Item Schedule, you can view all accounts that have Line Item support details and use the information in reporting. To do that follow the below steps:
On the data view toolbar menu click on the Support Details option
3 options will appear, click View Report , and the Line Item Detail report will be generated to view online, or you can download the report to an Excel file for offline use
Hopefully, this helps.
Good Luck!
