MDX Formula Help
I am trying to calculate the Gross Profit %, the formula works good for time perspective base, however when I choose TTM it gives weird results. So i decided to create a MDX which calculates the Margin based on whether it is base or TTM, but it is not working. Can anyone advise on the syntax.
IIF([Time Perspective].[Default].CurrentMember=[Base]
,([Account_Subaccount].[Default].&[GP]/[Account_Subaccount].[Default].&[4000])
,SUM(lastperiods(12,[Time].default.currentmember),[Account_Subaccount].Default.&[GP])
SUM(lastperiods(12,[Time].default.currentmember),[Account_Subaccount].Default.&[4000])
Hi Chaya,
The formula to create a TTM value for GP % (using the keys in your post) would be
(SUM(lastperiods(12,[Time].[Default].Currentmember),([Account_Subaccount].[Default].&[GP],[Time Perspective].[Default].&[BASE])))
(SUM(lastperiods(12,[Time].[Default].Currentmember),([Account_Subaccount].[Default].&[4000],[Time Perspective].[Default].&[BASE])))
If you are creating the formula in the accounts dimension, you may need to have 2 GP % accounts,
one for Base (using the first part of your formula), and
one for TTM (using the above formula).
FYI, the IF condition syntax for Time Perspective is
IIF([Time Perspective].[Default].CurrentMember IS [Time Perspective].[Default].&[BASE]
Feel free to let me know if you have any further questions.
Hope this helps,
Navin
Thaks, Naveen I tried tis but looks like something is wrong.
Sorry Naveen , I take that back, it worked after I also used Formula in Time Conversion. Thanks for your help.
Great to hear that you got it to work, @chaya.khannukar.
Would you be able to share the formulas you set for the Time Perspective and Accounts? Would love to know what / how you got it to work.
Cheers,
Navin
