October 2022 Product Adoption Tip: Declutter Report Mode
To make report mode look cluster free, it is good practice to disable run time for those dimensions with one resulting member or members that are not needed for end users. This can be accomplished by following the steps below:
a) Open a template in Design Mode. Expand the data view on the left. Under pages, right-click on any dimension that has one resulting member or a dimension you would like to hide in report mode and click Properties.
b) Once you click properties, you will be prompted with a “Page Dimension Properties: Dimension Name” dialog. Here you want to uncheck the visible at runtime option.
c) Once Visible at runtime has been disabled, preview the report, or open it in report mode. The dimensions that have been disabled at runtime will not be there.
Visible at run time makes it easier for end users to view dimensions they need to filter between.
A nice option for the template designers!
Thank you for this tip.
Thank you for showing this
This was a great tip.
This is helpful, thanks for sharing!
This option has been helpful to reduce confusion for budget owners.
thanks for sharing, it’s an useful tip.
Great tip. Thank you!
Use this all of the time! A lot better for the end user and less cluttered.
That is a very helpful tip. Thanks
Good info to know! Thanks for the tip!
Helpful tip. Thank you!
good option to be aware of
great option to incorporate into our reports.
Every thing like this that can be used to streamline options is great. Thanks for the tip!
This is good to know, thanks for sharing!
Interesting! Thank you!
Great tip for writhing reports and data views
