It’s my first delve into Detailed Planning and I need to create a formula for depreciating fixed assets on a 10% reducing balance basis. I want to show how the asset value depreciates each year where the annual depreciation is 10% of the NBV from the previous year, spread equally over each month.
I’m sure it’s simple enough when you know how…but I don’t…and I’m hoping you do
Thanks in advance!
There are a few ways of doing this. At an asset level, you should be able to use a combination of calc type (formula, accumulate, etc.) to calculate the value and spread thru the fiscal year. Best to reach out to a Product Adoption consultant and book a session to have them guide you thru it.
If you would like to add a specific example on how you would do this calculation offline, I am happy to try to give you more context on how to convert that into a DPM calculation.
I found a workaround by using the Anniversary Increase function with a negative percentage value. It’s limited to 6 years of course but that will be fine for my application.
