Time Perspective = Prior Year End
I am looking for a “Time Perspective” MDX formula that will point to prior year end. Example a calendar year will always pull 12/31 for the prior year.
Hi Tim, I believe this may be what you are looking for. Prophix Cloud Help - Lag Function
Scroll down to the section: Lag()
Thank you for the response!! This is not quite what I am looking for unless there is a creative way to use the “lag” function". I have a balance sheet where I present current month, prior month and prior year end (12/31/20). “time” is a page selection that allows you to choose any month. I have build a time perspective using lag for the prior month.
What I need is a time perspective formula that always pulls 12/31/XXXX for the prior year no matter what month I choose for the current month.
Thank you
Hi Tim,
Please see below the MDX formula to get to the prior year ending balance:
(ParallelPeriod([Time].Default.[Year],1, Ancestor([Time].Default.Currentmember, [Time].Default.[Year])), [Time Perspective].[Default].&[BASE])
Trust this helps.
Thanks,
Navin
@tim.allen My apologies for not providing the correct answer. But thankfully Navin saved the day by coming to my rescue, so thank you Navin! :slight_smile:
Perfect!! thank you so much
@bradley.kelly you may find this useful for some of your reports.
